JaZZ
Mark...
...of course there's an interaction of all the components which makes the sound. And of course it's not distortion alone that counts. E.g. the frequency response has a clear impact, but unfortunately it is virtually identical with modern amps. Within the measuring method stereoplay bases its theory on it's the hamonic distortion which is the measuring result, thus the deterioration of the original signal curve and the diverse harmonic distortion products this implies (representing fourier components not present in the source signal).
That's exactly my standpoint too, or should I say «was», in view of the stereoplay theory?
Agreed. But maybe if the theory finds acceptance, there is a new tool available to evaluate electronic components based on data sheets... (?)
Isn't it possible that whatever is being measured here is not "distortion" per se, but the sum total of all the individual components in the signal path in the amp that "colors" the sound with the combined signatures of all those parts? Obviously in addition to the differences in components used, circuit design, power output and other things will affect the sound of one amp vs. another. |
Also, just because we have invented 5 or 6 ways of measuring amps performance does not mean that those are the only 5 or 6 metrics that can ultimately be measured that affect sound. The tools available to us at this time for measurement may not be nearly complete enough to capture all that an amp is doing, leading two amps that measure identically to sound completely different. |
In the end, to me, measurements are useful in that they can tell you if an amp has any weird anomolies, but I don't think they're capable of relating how that amp will actually sound to the user. |
