ckhirnigs113
- May 19, 2005
Hi,
First of all I would like to say that I am adicted to Head-Fi. I check out the new posts a few times a day, and search for any topic I need an answer to. I often get more questions, but I enjoy the learning process.
Anyway, I have an iPod Photo and have been using the Ety Er6i's with it for about 6 months now. I have practically read everything concerning these phones and an iPod.
I think I have finally found a solution to the lacking bass of the phones. I was unwilling to consider a headphone amp because I really love my iPod for its portability. Due to constant tweaking and experimentation, I have recently been listening through the line-out using a PocketDock with an in-line attenuator (that I got from Radio Shack) to control the volume.
By doing this I have been able to listen without the documented distortion usually present through the headphone out of the iPod Photo (most apparent in piano solos). My bass problem was not solved until I discovered MP3Gain. At first I adjusted the gain of all 3,500 songs on my iPod to 92db. This level provides enough volume through the line-out for my needs. With the gain lowered, I am now free to use the iPod EQ without any distortion!
Bass Boost does wonders for the Er6i's! I can't believe how much fuller the sound is now that you can feel the bass instead of just hearing it accurately. The truth is it may just be my personal reaction, since I was so used to the anemic bass provided by the phones until the change.
As a side note, I can't force myself to listen through the headphone-out anymore. The sound from the line-out is noticeably clearer to my ears. IMO, the Bass Boost is just what the Er6i's needs (if you go through the line-out).
Right now, I don't think I need an amp. The sound is now clearer and much fuller than I could have hoped for without upgrading. I hope this helps someone out there struggling to decide whether or not to hang on to the Er6i's for a little longer.
Thanks. -CK
Thanks. -CK
