averydonovan
I try bridging the connection with my meter, but the amp won't power up.
My first readings of the problem came from the end of a mini-to-mini cable plugged in, but my 200mV rating is from pin 3 to pin 6. I have also measured from pin 3 on the OPAG to pin 6 on the BUFG with the same results.
And I am happy to report that I have solved the problem thanks to the person who emailed me. He suggested that I lift pin 5 since it was connected to the negative power rail. On the datasheet, pin 5 is for offset trim adjustment on the OPA627 and my offset was actually a negative amount. I lifted pin 5 and voila! Between pin 3 of OPAG and pin 6 of BUFG there is 0 offset now. Thanks very much to the gentleman who emailed me, and thanks tangent for your help. My amp is now in fully working order
Edit: I also posted this info on my site on the page about my PIMETA so hopefully others can avoid this same problem: http://www.donovansmith.us/content.php?article.21
