jimbobuk
- Aug 11, 2002
I was just having a quick listen to things last night, giving my SA5000 a go, and quite enjoying it, thinking they were revealing stuff i'd not noticed before (they weren't, but their presentation does perhaps make things a little easier to hear when they're in the background of the music)
i quickly tried my HE60s on the same track.. Following all the the things about getting the right voltages into HE90s/HE60s i've not been leaving them plugged in to my Stax SRM-313 all the time like i used to.
As i connected the HE60s with no volume on the amp, i did hear a noise come from them.. i think it was perhaps a connecting pop or similar.. i've tried it since with them on, and its not too bad, its similar hopefully to the sound it makes when you turn the amp on and off with the headphones connected.
Anyways after listening to them for a brief time i started turning things off to go to sleep.. i kept them on my head though and noticed this noise in my left ear. I went through turning things on and off, even turning the amp on and off to figure out that it stayed on even with the amp switched off (tho perhaps only for an amount of time whilst it discharged??)
I went to bed worried, leaving it on all night with my Omega's, wondering if it was charge related or not. Tried it this morning and at first they were silent again, i left them a little longer and tried them on my head again 20 mins later.. still silent. I noticed something i'd not really noticed before as much, putting them on and off if you get a good enough seal and you get that small noise like you do with the Omega's if you do the same.. this is the membrane being moved by the air.. i'm assuming this doesn't damage it, its hard to avoid with omegas sometimes. anyways i did it a few times noticing what it took to make the noise happen... part way through having done all this i noticed the noise had come back again.. I was in a rush to leave for work, but it was definitely back.. I'm going to leave it on again all day and have a proper look tonight.
Has anyone else had something like this before!? i'm really worried about them being damaged, though i can't imagine how. I'll fire up the HEV70 and see if that ever causes it to happen. hopefully it'll be the stax amp, or the adapter..
The design of the adapter without an outer ring round the stax end does mean its easier to insert the headphones one pin more than the others if its at too much of an angle, i don't know if this is what i did, whether this caused the noise i heard.. hopefully this is irrelevant and hasn't caused it, whatever is causing this noise to happen.
Is this kind of thing similar to a damaged diaphraghm, this quiet noise out of a driver whilst silence.. what is the symptoms of such a thing?
What's the right process for inserting and removing electrostat headphones.. should you have to turn off the amp before plugging in, removing them!? i'd never done it before, and i think i'm being a bit too paranoid.
Hopefully its nothing, or its stax amp driven related.. if not i'll enquire to Sennheiser about repairs, which at least shouldn't be too much, if they have the parts, to even do a full replace of the "driver".
