My guide to making foobar pretty (usable).
Jun 27, 2006 at 12:11 AM Post #106 of 255
Originally Posted by shuy
thanks for reply!
yes, i did add the album column to see which songs weren't tagged, so i could manually tag all of em. i've since taken that column out. situation's the same, but if navigator uses track number to determine its display, then there's my problem.
is there any way to teach navigator to do it another way? as u can see, i don't have full albums as i delete the songs i don't like. if not, is there any way just to display artist name alone? in default artist column, the artist name gets repeated every line, while i prefer just 1 line at the top for the list of songs by that artist.
Navigator in album mode does expect full albums. However, Navigator has two display modes, album mode and singles mode. Try it out.
  1. Click file->preferences->display->Columns UI
  2. Make sure you're on the main tab and click the import button.
  3. Make your way into the components folder. If you extracted the navigator columns ui configuration here there should be a folder called navigator something. Go in there and open the file that says singlemode.
Jun 27, 2006 at 6:34 AM Post #107 of 255
that's helped alot, though it still repeats the artist n album every line, its alot better than the previous display.
thanks!
Jul 2, 2006 at 11:53 AM Post #108 of 255
Hmm, maybe I'm just not seeing it, but is there a dll to make 9.2 handle wma files? I have a LOT of wma lossless files.
Jul 2, 2006 at 12:10 PM Post #109 of 255
There isn't one, because it isn't necessary. Native WMA support was added starting in 0.9.1.
Jul 3, 2006 at 8:06 AM Post #110 of 255
Ah, great! Thanks for the info!
Jul 4, 2006 at 5:00 AM Post #111 of 255
One last thing to work out and I'll have it the way I want it, and will post my fcs. The last snag is that it doesn't seem to always handle vbr formatted files correctly. I get most of my vbr's, which probably average about 200 kbps, displaying in the Quality column as 32, 64 and 96 kbps, so the song lengths are wrong, too. I suppose it's doing some calculations, and when one is off, so's the other. Strangely enough, though, in the system tray the bitrate is correct, but the track length is still wrong. Any idea how to remedy this?
Jul 27, 2006 at 6:08 PM Post #112 of 255
Just a bump since basic Foobar config questions are coming again; This is the best thread I know of to show people how to set up a decent GUI in Foobar 2k.
(*Renewed Plea for stickie*)
Jul 29, 2006 at 10:17 PM Post #113 of 255
What are some of the plug ins that work with 9.2 and the ones that dont? Im trying ot configure but itsnot going too well.
Aug 8, 2006 at 6:00 AM Post #119 of 255
someone on a different forum i visit posted this pre-configured version of fubar with a bunch of plugins already on it. the guy had gotten it off of a reliable private torrent, heres what they said about it:
Nobody wants to spend 3hrs locating plugins and writing crazy code in order to make the world's greatest audio application actually tolerable to look at and use. Some crazy Russian has done it all for us! (please ignore the fact that the installer is in Russian)
http://img463.imageshack.us/img463/6...titled0da1.png
Foobar2000 highlights include:
1) Audio formats supported: MP1, MP2, MP3, MP4, MPC, AAC, Ogg Vorbis, FLAC / Ogg FLAC, WavPack, WAV, AIFF, AU, SND, CDDA, and more!
2) Easy right-click file format conversion
3) Full unicode support.
4) Advanced tagging capabilities.
5) ReplayGain support - both playback and calculation.
6) Customizable keyboard shortcuts.
7) Tabbed playlists.
Cool Gapless playback
9) MP3/CUE support
10) Low memory usage
11) Audioscrobbler plugin support
12) iPod support
13) Audiophile-approved! winkz @ u boi
Highlights of this particular pack include:
1) The ability to play DTS files (which is rare and "illegal")
2) The ability to play the contents of RAR/ZIP files
3) You can change a song's rating by selecting it and typing Ctrl+ and Ctrl-
4) Sortable rating column
5) Quicksearch Panel
6) Album art display
nevermind
Aug 8, 2006 at 11:12 AM Post #120 of 255
I have a few questions.
1. What do I have to add into the track info panel's formatting string so that it will follow my cursor all the time? Now it only shows info of the track which is playing.
I would also like foobar to follow cursor all the time. So if I have one track playing on playlist A then if I select other track from playlist B I would like it to play next. Now it plays the next track on playlist A.
2. Where can I get custom buttons for 0.9.3?
3. Where can I get history panel for 0.9.3?
