Glmoneydawg
I also feel like these guys actually listen to music before it gets put online.....ussually the best mastered versions.So far anyway .
The streaming paradigm is here to stay, eh. For songs that I really like, I seek out the disc, buy it, rip it, and store it.I'm 58....this streaming thing is a huge step for me...being able to pick individual tunes off albums that i wouldn't normally play because the rest of the album is weak,swapping genres for a song or 2 ...huge....i tend to let one song lead me to the next ...from blues rock to blues to jazz to classical to metal or punk...very cool and convenient.
If you have the space for FLAC, why not use that? I'm not saying I can tell a difference, but it just seems like another step to encode everything to lossy files rather than just listening to the original lossless file.
@Steve999 If you use Apple devices, then it makes sense to use ALAC. I think there are some slight file size compression differences but for the most part they are just different means to achieve the exact same result.
the general rule of thumb is to do things for apple, because you know Apple is not famous for bothering to try and increase compatibility. sort of the exact opposite TBH. that's how they have users to keep purchasing other apple gears, because of how closed their system is. so you often don't have much choice when you use various systems but to make things compatible with your Apple gears, and then look at how to make the rest also compatible with the right settings or app.This I know. But what if my family of 5 uses my library and they use all ecosystems. . . Linux, Ios, OSX, android, Windows, etc. Then what. .. ALAC, FLAC, or is either a massive waste of time and effort? I vote massive waste of time and effort based on what little I know.
Whereas AAC or MP3 gets everything where it needs to be for everyone for the long haul.
ALAC is actually an open format isn't it? It isn't Apple's fault that PCs don't support Apple's lossless format as widely as FLAC. I think it goes both ways.
Did ALAC go open source after AAC? That format is pretty universal now
AAC is not open source. Apple Lossless is though.
