Originally Posted by sygyzy /img/forum/go_quote.gif
Does a TS, TRS, and 1/4" plug look different from each other, physically?
TS and TRS means two or three contacts--
not the size of the plug!
1/4" TS (a Canare F15):
The same series plug in TRS configuration (a Canare F16):
Likewise, you can find mini plugs in the same series, either TS or TRS..........here's a Canare F11, 1/8" TS (though often called just a "mono mini plug"):
And a Canare F12, 1/8" TRS ("stereo mini plug"):
Putting it all together:
1. TS and TRS mean "tip, sleeve" and "tip, ring, sleeve", respectively, for what are known as "phone plugs". Small consumer gear often uses the 1/8" (aka 3.5 mm) versions, larger consumer and pro audio gear generally uses the 1/4" version. (There are two other styles of 1/4" plugs that are known as "military/longframe" and "tt/bantam"......do not buy those!)
2. TS and TRS do not necessarily mean a 1/4" plug or jack, though those terms are more often used for 1/4" than for 1/8" connectors.
3. Because a TRS plug can carry a stereo unbalanced signal, it's not right to assume that TRS means a mono balanced connection.
And scompton, I think you need to get your males and females straight.......plugs are the (rather blatantly?) male part attached to your headphone cable.....jacks are the female component on the headamp/player/source.
Yes, I know that the jacks in a deck of cards are males, not females. But what used to confuse me is why a female threaded connector that mates with a bolt is called a "nut"! Given that females don't, umm, never mind......
