mrwinick
- Jun 12, 2004
I answered that one for myself. It does. Now, does it matter if I use the mini jack or the two 1/4" jacks? Any noticeable difference? Thanks.
Originally Posted by mrwinick /img/forum/go_quote.gif I answered that one for myself. It does. Now, does it matter if I use the mini jack or the two 1/4" jacks? Any noticeable difference? Thanks. |
Originally Posted by mrwinick /img/forum/go_quote.gif yes. I ran to guitar center to buy one and then hooked it up immediately. It's been hard to get anything done that doesn't include sitting in front of my computer. Every time I make a change lately it seems like I'm taking a step closer to the music. It's pretty amazing what a relatively small investment (time and money) can do. |
Originally Posted by SuryA /img/forum/go_quote.gif Ok i'm prolly going to buy this as an external dac for a speaker setup and also for my headphones. Just one stupid question: the trs or rca outs that I would use for my speakers are not amplified by the emu, are they? |
Originally Posted by Exocet85 /img/forum/go_quote.gif On install, the manual sais to remove all other soundcards / disable onboard sound. I currently use onboard sound on an ASUS motherboard, however I'm stuck with a problem: I don't seem to get into my BIOS, everything just freezes when I hit the 'Del' button. Besides this, my pc works fine. I have tried many thing including Bios flash and CMOS reset, and asked others but no luck so far. Anyway, I know most guys here are more into audio then the die-hard pc stuff, and I just want to listen to my EMU, so let's stick to that: Does anyone have experience with using an EMU 0404 USB next to an onboad soundcard? I can image it might run into issues concerning the windows mixer bypass. Are there any special means/methods to install such a configuration? I can ofcourse uninstall the drivers and remove all my onboard soundcard software (without disabling in bios), but will this do the trick? Any help is greatly appreciated! Thanks in advance! |
Originally Posted by scompton /img/forum/go_quote.gif I had to disable my AV710 to get sound from my 0404 USB. And to get the AV710 to work before, I had to disable my on board sound, which had developed a loud buzz anyway. At work I use a Silverstonetek EB01 which is recognized as USB speakers. I had to disable the on board sound to get the EB01 to work. On my laptop, both worked without touching the control panel. I guess it just depends on the computer. BTW both my work and home desktops are old, so that may have something to do with it |
Originally Posted by sejarzo /img/forum/go_quote.gif Assuming you are using XP, even if your desktops are "old"........did you first make (or attempt to make) the 0404 USB the default device under Control Panel>Sounds and Audio Devices, or is your work computer possibly a Win2k machine (I'm guessing that could make a difference)? |
