My EAR++ just arrived - first impression.
Apr 5, 2006 at 2:42 AM Post #31 of 31
Originally Posted by mrarroyo
Afrikane and replytoken if I may suggest get a cheap cheater plug. Run your setup as you normally do and verify the hum/hiss is present, then turn either the source or the amp off and install the cheater plug on one, then reverse the polarity by turning the plug 180 degrees. If the hum/hiss is gone the problem was an easy to fix and you can send me a $100 honorarium check
Already tried that with no success.
