Is anybody using their EAR++, or possibly an older EAR model, as a preamplifier? I am still trying to iron out a floor noise problem (as I described in another post), and I am about at my wit's end. While I believe that the issue may be stemming from my integrated amp being very sensitive as a stand-alone power amplifier, I will not have access to another solid state amp until later this weekend to test this theory.
In the meantime, I have ordered and swapped out my signal tube for a lower gain type (12AY7 instead of 5751). This eliminated some of the microphonics that the stock signal tube was displaying, but it has done nothing for the noise floor that some think is a tube rush sound. Do tube preamp owners just live with tube rush and high noise floors? Is it possible that another solid state amp may present the same problems? I have the EAR set at its lowest setting, 5dB, and Dr. Lloyd has checked his schematics to make sure the design is OK. Its a great sounding preamp and headphone amp, but at low passages the floor noise is very noticeable.
The only patchwork solution I have not yet tried is Rothwell In-Line attenuators. Some say they have minimal impact on the sound quality. Others believe they are very degrading. They are not readily available, nor are they dirt cheap. My wallet is already hurting, and my belief that things would synergize to an acceptable level is also taking a beating.
Dr. Lloyd and I went over the amp specs. several times so I am a bit puzzled. Also, the EAR is very quiet as a headphone amp. Is this problem isolated to my system, or have any other EAR owners had similar preamp issues? Any suggestions would be greatly appreciated, because the next immediate steps to resolve this issue can be quite expensive, and involved.
