svyr
- Jun 8, 2009
http://www.soomal.com/doc/10100002155.htm
http://www.soomal.com/images/doc/20110627/00011734_01.jpg
http://www.soomal.com/images/doc/20110627/00011738_01.jpg
http://www.soomal.com/images/doc/20110627/00011739.jpg
Optical out/usb in, line out, 2HP ports (relay switches Line and HP in the control panel)
The usual xilinx fpga, (well, not usual, same as MD11)
PCM1798 DAC - http://www.google.com.au/search?client=opera&rls=en&q=PCM1798+DAC&sourceid=opera&ie=utf-8&oe=utf-8&channel=suggest
TI TPA6120 HP amp.(resistors and caps) err https://docs.google.com/viewer?url=http://focus.ti.com/lit/ds/symlink/tpa6120a2.pdf ?
The silver/gold bar thing seems to be the Silicon Labs 598 prog clock used in MD30 (opt and usb i presume... Since USB is in bulk mode, either that's the required clock for the USB 2.0 implementation... Or maybe a clock for opt out
(idk if it needs one
USB3 via Cypress cy7c68013a (2.0 compatible) and bus powered (lol what, http://www.cypress.com/?rID=38801 no usb 3 support on that chip, just the plug then?).
Presumably in bulk transfer mode again. (error checking and retransmission for USB mode)
LCX245 chip for opt/musilink http://www.fairchildsemi.com/pf/74/74LCX245.html ?
MC33079 op amp for line out. http://www.onsemi.com/PowerSolutions/product.do?id=MC33079
The HP amp should have enough juice to power most low impedance cans and aside from the questionable MC33079 quad op-amp on line out, it should be an interesting transport/budget source. (I presume the price will be around 150-200 USD)
Musiland release Monitor 03 US sound card, the card is still using FPGA, the structure of the previous generation is not a big difference, but the hardware to do a new design. 03 US using PCM1798 DAC chip, performance has improved, headphone output section to be strengthened. In order to better power supply to optimize the power supply design, compatible with USB3.0/2.0 take power [3.0 to provide greater output power]. Soomal will be held July 10, 2011 release of the product evaluation report.
