Lil' Knight
- Sep 16, 2007
Would be interesting if there are some comparisons with the M-audio Transit.
Originally Posted by Mik /img/forum/go_quote.gif So far it sounds as good as the Trends, with the added bonus of supporting higher bit and sampling rates. You don't have to fiddle with asio4all on the Musiland. The Musiland is also smaller, and looks and feels better than the Trends. That it sounds the same as the Trends at 16/44.1 is actually a good thing in my opinion. I've heard usb audio conversion done poorly as well. For example, the Trends (and Musiland) both sound better converting usb to spdif than does the usb to spdif converter built-in to my DacMagic. All that and the Musiland is less expensive than the Trends. I can easily recommend it as my favourite usb to spdif converter to date. I can't say whether there will be any issues running it on Vista or Windows 7 though. |
Originally Posted by krusty09 /img/forum/go_quote.gif yes it has one usb input on one side and a bnc and optical output one the other. this works with vista 64bit home edition and it sounds great with my stello dac. |
Originally Posted by DoYouRight /img/forum/go_quote.gif USB to optical work? since they are on the same side? Or do you pick one and output to BNC/RCA? THIS LOOKS SWEET! |
Originally Posted by DoYouRight /img/forum/go_quote.gif What I mean is, usb > bnc/rca but can it do usb/optical since both are on the same side of the unit. i know usb is the start, are their 3 end points? bnc, rca, optical? |
