Another dud...
You would think Pink Floyd would be the perfect candidate for multichannel, but it really isn't. The original LPs had VERY complex mixes, with sound effects, music and a swirling array of phasey ambiences drifting in and out from bar to bar. The problem is, when they go to build a 5.1 mix, they're starting from scratch on all that. Trying to guess how effects were created thirty years down the road is just about impossible. Pink Floyd used every engineering trick in the book, and often completely different techniques were carefully dovetailed together and they changed with every verse and chorus. I can only guess at the time and thought process that went into mixing these albums, along with input from engineers, producers and the band themselves. When a 5:1 mix is done, too often they just hand the masters and the stereo mix to a single engineer and say, "Here. Make 5.1 out of this." Good luck getting anything close to the original sound with that approach.
One of the first thing I learned about sound mixing was that everything starts with the vocal track. The first pass at the mix is balancing the vocals... compressing them so the consonants all read clearly, making sure they are all at a consistent level. Then you go in and start laying in the various levels... drums and bass, rhythm guitar, lead guitar, keyboards, etc. At each stage, you do little adjustments, smoothly dipping a track a little for a fraction of a second to poke a hole for a particularly important word in the lyrics to have a clear space to read. Listening to the finished mix, you have no idea how many tiny edits it took for a big pile of sounds to all read clearly without bumping into each other or sitting on top of something important. When you pull the original elements and try to recreate that, inevitably you end up with sloppiness... wallpapering in layers without finessing them at all. That's what we have here.
Anyone who grew up in the 70s (and smoked pot) knows every inch of every Pink Floyd album by heart. That makes it doubly difficult, because you have to compete with the original mix that is embedded in a whole generation's brains. As I sat down to listen to this, I immediately flashed back to when this album came out and I played it on my turntable. I think it came wrapped in opaque blue shrink wrap, so you couldn't see the cover inside. It didn't matter because the sticker on the front said, "Pink Floyd's new album" which was all kids my age needed to know to pull out the five bucks and buy it.
As I listened to the beginning, I recognized the specific guitar licks and vocals, but I had to strain to hear them. The mix was thick overall, nothing was highlighted. The vocals were recessed and muddy sounding. You had to strain to hear the lyrics. Musical accents that used to be foregrounded were now buried under the sludge like basic track. Worst of all, the carefully dovetailing kaleidoscope of ambiences were replaced by a handful of digital reverb settings that cut in and out with obvious potting up and down. Yes, the requisite "flying around the room" stuff is there in Welcome to the Machine, but a lot of the other tracks have stuff flying all over, and it didn't work at all. For instance in one song, a guitar solo was broken into four bars and each bar was played through a different speaker. That made the solo completely disjointed, as if there were four guitarists finishing each others' sentences like Huey, Dewie and Louie.
It was pretty clear what happened here. Some poor engineer got handed a "no win" situation, and didn't have the budget or resources to start from the ground up the way good mixes are built. Instead, he built it all at once from all the pieces and just tried to dial in and out stock ambiences to approximate the sound on the album. Then he pulled some bits out and threw them around the four corners of the room and called it a day.
It really made me appreciate the Elton John SACDs. Those are completely true to the original mixes, and I bet the way they accomplished that was to bring together the original people who made the albums in the first place and had them do the surround mix, not just some anonymous engineer whose only connection was that he went to a Pink Floyd concert once when he was a kid.
This one is a mess. Don't waste your money on it. Just buy the standard CD on this. It sounds great.
