jagwap
Which part of "from a Redbook definition" did you not understand?
So from your very singular position, decoded MQA is lossless?
Here is Benchmark's critique of MQA:
https://benchmarkmedia.com/blogs/application_notes/163302855-is-mqa-doa
benchmark talked about 18bit flac being smaller than MQA, which can be a death sentence to MQA if it is evaluated properly and generally applies to various musical content.
but benchmark haven't said much about the 18bit source: is it dithered (i bet not)? on what content?
as of the unknown 18bit pcm having better quality than MQA...well, that's their opinion, i don't know...
From a Redbook POV?
Probably (or nearly so), but where the lazy filter (necessary for that reduced ringing) of MQA starts to kick in matters, as well as the ability of the origami algorithm to restore flatness.
Graphs like this make it looks like it starts to kick in at around a sample rate of 30khz, which is below Redbook standard:
Which ends up shaving a teensy bit from the top octave:
Which is then supposed to be fixed by the magic origami unfolding process:
I haven't seen any independent tests yet on just how well this works and if there are boundary conditions in the algorithm solution set that cause problems.
And how true in audio terms can we regard the results given the appearance of aliased components that were not present in the original recording?
This is all highly theoretical and I'd like to see more direct head to head measurements.
Did you click on the link the article? It would have lead you to:
http://www.computeraudiophile.com/blogs/miska/some-analysis-and-comparison-mqa-encoded-flac-vs-normal-optimized-hires-flac-674/
There is discussion in the comments section regarding dither.
My understanding is that the "lazy filtering" or apodizing filter only effects those frequencies when the sample rate is 44.1 - 48kHz. When reconstructed to 96kHz the low pass filter poles are doubled in frequency so the 20kHz passband is untouched.
Also it is generally part of the DAC, so may not be there in the digital file. Not sure on this, but it seems likely.
i know this is a funny idea but maybe it can be subjectively evaluated by amplifying the very quiet moments in music, and slow it down to make ultrasonics audible?
Looking on my phone again. Redbook is the standard for CD. It does not include sample rates other than 44.1kHz or more than 16 bit. So 30kHz is way above the filtering requirements of redbook.
Yes, it was ridiculous late at night. I conflated sample rate and filter in my haze. Fixing post.
those things are crucial, MQA guys must have some reason to use such a complicated scheme afterwards. it all comes down to compression ratio.
personally i would consider MQA really revolutionary if it can achieve ~2x compression ratio than flac on the same 17bit ditherd (or 24bit source) pcm stream, given the quality loss is as small as they claimed.
anyway, it is an interesting compressor
