Originally Posted by archosman /img/forum/go_quote.gif
Based on your rantings and ravings I wouldn't listen to anything you say either...
Originally Posted by Chu /img/forum/go_quote.gif
Quite honestly, if it take $15K cables to get better sound, that's the point where I have to pass.
If you had read my posts in other threads you would have seen I get better sound for a fraction of the price. I built a system that gives the best sound for as little money as possible. A single Valhalla power cable is enough if you cut it open and use 1 conductor per signal.
I have cut open my Valhalla interconnect to make a direct comparison against my Valkyrja speaker cable, and the Valkyrja was better so I use that in my system instead, it costs 1/30th of the price.
I have removed the daisy chained power conditioners because they were compensating for the lack of bass of the Valhalla interconnect. And since I removed the power conditioners I didn't need extra tweaks for them.
I have removed PS Audio Gain Cell pre-amp and I use the built in pre-amp inside Benchmark DAC1, I have the Valkyrja speaker cable hardwired on both ends, no expensive connectors are needed.
Even plugging everything into the wall sounds acceptable. Power conditioner wasn't needed because it sounded very smooth from Valhalla power cord and Magix levitation feet. Even ERS Paper wasn't needed because it sounded smooth enough. There weren't any dynamics but it still sounded very good.
Vibration isolation was what gave the biggest improvements for me. ERS Paper added dynamics and low-level detail, it isn't expensive at all compared to power conditioning. The problem with power conditioning is that it adds weaknesses.
I have $$$$$ gear sitting in boxes because they make the sound worse, all of them are mutilated and I can't sell them. But I don't care because my audio hobby is complete, it can't get any better, and it's also easier to replace if something breaks. My system went from $50k to below $10k and the improvement in sound quality is the biggest I have ever heard. It was because of the tweaks and knowing what to do with them, but people don't want to listen.
