Sceleris
- Feb 27, 2008
Regarding the AD900s and emphasizing the shallow earcups previously mentioned by Amarphael, I wanted to add that if your ears stick out to any degree like mine, then chances are that they are going to be right up against the driver and rather uncomfortable. There has been some discussion in other threads saying that if this is the case, wearing the headphones as far forward as possible tends to help. I tried this and it did help a little, but still found that my ears were touching the driver and still hurting after extended use.
Stuffing some rolled up tissue (you can use rubber tubing too) under the rear half of the pads to deepen the earcups has helped a lot with comfort and for me at least, hasn't really changed the sound too much (look up phat pad mod). So discomfort issues can be fixed with a simple mod.
Regarding portability - in addition to the open design and lack of isolation, these cans are huge, the fit is fairly loose and they can fall off fairly easily. Also, you're going to have a lot of cable to manage using it on the go.
