dansker4584
- Jun 20, 2014
Yes, I have tried using guifoemat32 and the Sad format utility from SD standards org. No luck.
how many sub folder in there? the current firmware only support 256 sub folder and the new firmware will fix this bugs, anyway, the more sub folder , the slowly X3 will be. so we suggest you can separate to several folders.
Just out of curiosity, this sub-folder issue had been fixed in the Firmware3? B/c I just bought a new sandisk 128 gb microsd and having hard time get my X3 read it properly. Nevertheless the card is full music, only like 28 gb of them is appearing in the X3...
Well, on my PC it is the same. I mean after 20 gb it slows down extremely (the copying process) and at the end the folders are there but the music is missing if I open the folders, except the first two - three folders. Same if I put the card in my X3.
I got my card in a genuine sandisk wrap, the card looks authentic, too...I'm stuck. Any idea anyone?
Have you tested it with the link I provided?
It's a long process, but it will tell you if the card is genuine or fake...
Yes, I have actually started to read this thread like 2 hours ago and bumped into your post offering this test on the first page. It is running for an hour now. We shall see. Is it foolproof though? I mean this test.
I provided the link to the test in my reply to you post #169 Test here - there was no need for you to search for anything.
Is it foolproof - more info here
I've been using Adata 64gb for last 4-5 month without a single problem.
