Moon Audio Blue Dragon - which termination type for audio-gd master 6?
May 20, 2012 at 2:13 AM Post #2 of 3
Mad Max
USA
Whichever.  I suggest 4-pin.  Less weight, somewhat less work if you are doing the termination yourself.  If you use two 3-pin XLRs, you will only use two pins of each connector, so might as well stick with 4-pin for the sake of simplicity.
Some bling-bling XLR plugs only come in 3-pin versions.
