Chu
- Jun 22, 2001
I used to think that Monster were good but overpriced. After their new THX line I try to avoid them whenever I can, the terminators drive me insane.
I hate these.
1. The 1/8" jack is way too fragile. It will bend solely under the weight of the cable.
2. The 1/8" jack is far too wide. It interferes with other ports on most sound cards, and also many other sources that use even slightly recessed ports.
3. Almost every monster cable up to now has had screw on type terminators where you can undo the jacket and look at the mechanical connections, etc. These are encased in rubber.
I hate these.
