- Aug 2, 2014
Hey gents, I have a thought for all of you and would like to have some feedback from those who have very hot sources and need attenuation.
I know that some of you are using some kind of passive attenuation. In general, pure passive attenuation can affect the SQ because of the resistance introduced into the input stream turning the source from low impedance output to high(er) impedance output.
There is another way though. It would be a simple matter to create an active attenuator using high quality audio opamps. Attenuation would be done with a simple voltage divider before the opamp inputs. The easiest way to power such a thing would be two 9V batteries.
The advantage of this is that the source would still see a high impedance load, but the amp would see a low impedance source at the outputs of the opamps.
Batteries would ensure no significant noise introduction at the input to the amp beyond the inherent component noise.
I don't think the opamps (chosen properly) would have any audible effect on the SQ because the opamps would be operating in a very lightly loaded situation which would not incur significant THD, etc.
So just an interest check. Anyone interested in this? And if so...
1. Is my proposed method of powering ok?
2. What gain reduction would you want? Cut it by 1/2 (6db). Less? More?
I don't think something like this is needed for most situations, but there do seem to be some where it might be helpful.
Perhaps a switch for -6db and -12db. IMO, anything under 6db will be useless. -12db might add some versatility for extra sensitive headphones like the Cascade or Fostex TH models, which both match SUPER synergistically with the LP.
