I'm having trouble finding it in this thread, I know it's there, but... does anyone have a list of the required caps to mod the LP? After cutting my teeth on a Darkvoice and then a BHC I'm itching to give it a try.
Or should I just stop being lazy, crack it open and look for myself?
Open it up it's more fun that way. And remember, new caps only need to match the capacitance value exactly. Temp rating can be higher (but not lower) than stock.
I'll be really curious to see you swap the pot. We did it last year over the summer with an Alps rk27 pot. Required some significant plate modifications.
Was it a problem of depth? I know the rk27 well and thought I was gonna need a crowbar and a sledge to get one into my Darkvoice. Those little Dact-style attenuators on eBay are tiny in comparison so might be less of a fight.
Overall size problem. The Alps had to be wired in laying on it's side due to the height restrictions from board to chassis , resulting in the plate having to be drilled out 1 inch left and a quarter inch up. Then the process of filling in the old hole and putting a new finish on it. Here's what mine looked like after the plate mod.
Hey guys, be kind and identify what "substances" you're imbibing (or inhaling) on this Liquid Platinum boat. No way I am being left out. I want in on the party
So I'm definitely having what you guys are having, so name the brew or cocktail or whatever's inside the pipe
