So far not seeing anyone clearly recommending this over LP given the large price difference. Per that review if seems high powered planars or if you dislike tubes would be the use cases
I suspect that most people who have a Liquid Platinum/Crimson/Fire and just got the Liquid Gold X will immediately recognize that the Liquid Gold X is a different amp with its own unique sound characteristics and that it would be unfair to the amp to do a quick take on the amp just to get a quick impression out there.
I bought the Liquid Gold X a week after release. So I've owned it for less than 3 weeks. I haven't been listening to it enough yet to get critical about its sound or do a review type commentary. I bought some new tubes for my Liquid Glass at the same time I got the Liquid Gold X and I've been far more interested in listening to those new tubes in the Liquid Glass that playing with the new toy Liquid Gold X. So the Liquid Gold X has gotten few hours (relatively) during that time. I haven't listened to it enough yet to have critical comments. I also don't have enough different headphones on hand to be able to test it with enough different headphones of different flavors to figure out what headphones pair with it best.
The reality is that the Liquid Gold X is a different amp than the Liquid Platinum and other Cavalli blended hybrids. The Liquid Gold X isn't just a solid state version of Liquid Platinum. It isn't a Liquid Platinum with no tubes. It's not like that at all. It's a different amp with its own characteristics that will pair differently with various headphones than the various Cavalli blended hybrid amps. Comparing a Liquid Platinum directly against a Liquid Gold X will ignore the unique character of each amp and what pairs best with each.
The tonality and character of the Liquid Gold X is different than my Liquid Platinum and Liquid Fire. The tubes in the Fire and Platinum seem to fill in the midrange better than the Gold X. So with a headphone like the LCD-2 Classic that takes a bit if a dive in the midrange the Fire and Platinum fill that in and make it so it doesn't sound like the LCD-2 takes so much of a dive in the midrange. The Gold X doesn't do that. So I notice the frequency characteristics of the LCD-2 Classic more. Makes me wish I had a LCD-X on hand to try with the Liquid Gold X to see if the way the LCD-X extends a little more in the midrange will pair better with the Liquid Gold X.
Another example. I have an Oppo PM-2 and a balanced cable for it. The PM-2 is more neutral through the midrange than the LCD-2 Classic. Tonally in the midrange it pairs better with the Liquid Gold X, but the PM-2 does not have the transparency of the LCD-2 Classic and the Liquid Gold X makes that obvious. The Liquid Gold X is very good at letting me know which of my headphones have more transparency than others. Better at that than the Liquid Platinum for letting me hear how transparent a headphone is (I define transparency as the ability to hear through the headphone, have the headphone disappear, and hear through the headphone and amp to the source component and recording). The Liquid Gold X makes me wish I'd have splurged and gotten an Audio Zenith PMx2 mod. Expensive, but I think the PMx2 would end up pairing quite well with the Liquid Gold X.
Another example. I have an HD580 and HD600 that are both 20 years old. I also have a HD650 that is 5 years old. I have balanced cables for them. Tonally the HD580 and HD600 work better with the Liquid Gold X than the HD650. The HD580 is a bit more shouty in the mids than the HD600, but that's the way those two always have been. The Liquid Gold X makes that more obvious. But the HD650 has much better transparency (the Senn drivers have improved over 20 years) but the HD650 tonality isn't pairing as well for me as the older HD600 tonality. With the Liquid Platinum I prefer the tonality of the HD650. With the Liquid Gold X I'm preferring the tonality of the older HD600. But for transparency I greatly prefer the HD650 on the Gold X. The Gold X really lets you notice the transparency of the headphones you try with it. More than the Liquid Platinum, and about similarly (but differently) than the Liquid Fire. The Liquid Gold X doesn't let the headphones hide, for better or worse.
The EnjoyTheMusic review of the Liquid Gold X said the Gold X sounds like a Liquid Platinum with a really sweet set of tubes. I don't think that is a good take. I don't think that is a good way to compare the two so easily. I don't hear the two amps being similar in that way. The two amps are very much their own. Each different. Can't compare them in that way. A simple comparison like that is unfair to both amps. Evaluate each on their own with headphones that pair better with each.
The Liquid Gold X does sound different in low gain and high gain. Low gain is softer smoother more Cavalli liquid sound. The high gain is harder and changes the midrange tonality and overall soundscape style. The soundstage closes in with high gain. I prefer the low gain. Low gain is more like the Cavalli relaxed style of sound I'm accustomed to. The low gain and high gain are different enough that I think of them as two different amps. Any reviews of the amp need to mention which gain setting was used. I've been using the low gain.
I've never been able to hear the original Liquid Gold. This is the first time I've been able to hear any flavor of the Cavalli solid state Liquid Gold style of sound. It's different and better than the solid state sound of the Liquid Carbon. The solid state sound of the Gold X has a take on sonic holography that is uncanny for a sold state. It's reminding me a bit of the sonic holography that tubes can do, but to a less degree while being more solid state accurate and clean. I've considered my Liquid Fire and Liquid Platinum to be 75% Cavalli solid state sound mixed with about 25% tube. But predominantly a Cavalli solid state sound take on sound with about 25% tube mixed in. The Liquid Gold X helps me understand that mix and ratio better. The solid state side of the Fire and Platinum must have a similar style of sold state sonic holography going on then mix in a bit of tube to add a bit more and add in some second harmonics and other harmonics.
The Gold X makes it clear to me that I need to listen to it with more headphones. Especially some headphones like the LCD-X and Abyss Diana and some other planars that are more neutral through the midrange than my LCD-2 Rev 2 and LCD-2 Classic. Unfortunately I don't have access to headphones like that right now. And with Covid there aren't any meets where I'll be able to go try different headphones.
