Indrajit
- May 23, 2015
do not throw away your money into chinese cables. I did a lot
Just recently, we have made big comparison of various cables with various headphones and turns out all chinese cables sharpen the sound in unpleasant way. Right now, I am still using one of the bad ones with my M1570, but gonna order another FAAEAL cable tomorrow. Why? It is the only cable that sounded good out of the bunch we had tested. Fortunately, they are not selling it with miniXLR connectors and that is also good thing. I would never trust any chinese XLR connectors. Personally, I use (Neutrik) Rean and they are good for sure. The best thing is to order FAAEAL cable, arrange with producer not soldering MMCX connectors and solder Rean miniXLRs yourself. It is easy, really. Their coating is rather weak, also visually not the best, so using cool nylon covers is advisable. You will spend 20-25$ and get yourself outstanding quality cable. I will compare FAAEAL with Neotech NECH-3001 and see if there is any audible difference between them.
About M1570... we also tested them against GoldPlanar GL2000s, double magnet version, but very briefly.. and there was none superiority of one over another. Many folks say lately these GL2000s are so great, blahblahblah. Tuned between HiFiMan and Audeze. Yeah, they are. Layering, soundstaging is great, but tonality and midrange not the best. Probably need some very careful amplifier matching to sound truly best. M1570 are way more universal, easy to match. After auditioning tens of headphones, I must say M1570 are reaaaally cool, especially after EQ and running them balanced. Stock they are just good, but with big weaknesses, like cramped soundstage and uneven FR.. but after EQ? These sound superb. Better than LCD-2C. On par with LCD-2 Shedua or maybe just a very little inferior, but come on, these cost double the M1570.
I use oratory1990 EQ with additional 6.5kHz -3dB to reduce "s" sibiliance which is amplified by this chinese so-called 7N single copper crystal cable. Yeah, for sure it is 7N single crystal copper. F*ckinshit, mehh.
Loving my M1570!
I have a Hiby R5ii + a Sennheiser HD650. Recently bought a Faaeal 4.4 mm balanced cable for hd 650+hiby r5ii. While it delivers more power and loudness, it does sound a bit shouty or harsh compared to single ended. I just wanna know from you if u can whether this faaeal cable is genuinely a balanced 4.4 mm cable. There are a lot of fake balanced cables and connectors out there and i read they damage amps/daps. So is this faaeal cable genuinely balanced?
