Modifying WM1Z/A
Status
Not open for further replies.
Mar 29, 2020 at 9:24 AM Post #496 of 3,042
@Lookout57
Hi,
I restarted my mac and WM1A and used the universal still no go.
when I launched "SoftwareUpdateTool", it gives me the following in the terminal window
Failed to connect (rootMenu) outlet from (AppDelegate) to (NSMenuItem): missing setter or instance variable
2020-03-29 20:10:53.504 SoftwareUpdateTool[716:15564] return languages is ==> en
logout
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
Deleting expired sessions...4 completed.
when i accessed the content and manually clicked on "SoftwareUpdateTool" under SoftwareUpdateTool/Contents/MacOS/
it gave same error above about Missing setter or instance variable. but this time, it gives me the following Windows
then it continued updating with my dap restarting and the Mac showed completed.
I checked my WM1A under Setting/Unit Info, it shows 3.02 like original. Should I see Solis or something if the update successful? Thank you
What version of MacOS are you on ?
As I understand it you have to be 10.14 or earlier for it to work.
Mar 29, 2020 at 9:39 AM Post #497 of 3,042
@Lookout57
It will always show 3.02 regardless of which 3.02 modified version you install. If you install one of the modified 3.01 versions then it will show 3.01.
Mar 30, 2020 at 12:47 PM Post #499 of 3,042
Ok, here is the appropriate thread to post my 1Z mod. Thanks to @Whitigir.
It's been very interesting couple days after found out the best possible wire for S-Master active ground. Changed from fw solis3.02 to U3.01.
Clearly, purest copper is just not good enough IMO. Good improvements overall but it darkens the background a bit too much. It's not bad. In some sense it's like listen to vinyl records. But it keep me thinking in my mind it's might not resolved enough.
Later I try silver plated and there goes all the nuance lower level details, airiness/spacious from upper mid which I missed is back. But treble might be over aggressive sometimes.
2x silver plated or silver plated + copper wires will improve soundstage and warmth overall but I feel like it lags some resolution and speed from the bass.
So now I think if I can apply the same technique from 4.4mm negative terminal mod on to this and the result is much better. 22awg OCC silver plated wires with 22awg 2mm length OCC. Solder them on each side. Here is what I have noticed so far. Treble is just prefect and extremely resolved. Sounds like real thing. Never too aggressive no matter what you throw at it. All the nuances, sparkling, airiness, and spacious in upper mid is so addictive to listen. Never thought it would possible for 1Z but there it is. Resolution is extended even more, dynamic is heavier fast, very detail soundstage 3D like, depth has more details, longer decays and go even fairer back. All that make everything much more fun, addictive and very satisfying. Classical, vocalist records are so warmth, emotional, and very romantic. Much clearer and better isolation between instruments and vocals separation. Lower mid Sony sound signature is all there and even better (Loose it if use single silver plated wire). Sub-bass is fast, heavy, extended, and slower decays.
It turns out just copper wire for battery will make everything a bit more vailed. Silver plated makes treble north from neutral. Mixed two type of wires together will take care of those peoblems.
After all that, it seem battery runtime is lower now by 15 maybe 20%. I think my 1Z is so resolves now even connect to charger I can hear a small improvement in SQ. Maybe now I have to turn off battery saving mode to get the most out of it.
Apr 3, 2020 at 3:53 PM Post #501 of 3,042
@Whitigir : Thank you for this thread and the time you spent for us !
I need to read everything now, but since I start reading, this is very an interesting mod... :wink:
Apr 5, 2020 at 1:59 PM Post #502 of 3,042
Stellar work from Whitgir and Mobideath. I was looking forward to trying out the planet mods on my WM1a. I successfully downloaded them from Morbideath's Googledrive link last week only to realise I'd downloaded the wrong region versions (I meant to download J region but accidentally saved the European region files). I've now tried to log back in and it looks like the Googledrive link now has access restrictions / permissions set against it. Can anybody help me out or point me to an alternative link? Many thanks
Apr 5, 2020 at 3:13 PM Post #503 of 3,042
@nc8000 can you help out here ?
Apr 5, 2020 at 3:14 PM Post #504 of 3,042
Status
