Just bought some 28 gauge silver and copper sheets to upgrade my aluminum back cover mod I did few weeks ago. Copper sheets are more than 5x cheaper compare to even smaller size sheet of silver. G!
Very like how my 1A and 1Z sound so far after the mod. Hopefully that will eliminate distortion even more, maybe a little more resolution, background imaging, 3D holographic, ambiances, bigger larger bass and smoother pleasing treble.
IMO, WM1A sound quality could be much better if it has copper housing instead of aluminum. If your want to try and your audio gear are resolved enough, put the Walkman inside a thick metal box or something that be able to completely shield away from external noise. You will notice the difference in SQ.
