jTizMLG
- Jun 8, 2010
I'm having allot of trouble deciding between these 2.
I want to use it with the HD600.
Which one is better?
HI there,
I have the this Audio GD amp.
I used this amp with my LCD2 r1's and I found it to be a little too warm I guess.
I am fairly sure the HD600's are fairly dark as well, though I have never heard them so you may have the same problem.
However in this regard the Audio GD 5.32 has the Sabre Dac which is apparently more analytical (though apparently not bright) and may suit darker headphones more.
Depends on what sound you like. I found that bumping the upper range in treble up a little via eq, that I was very happy with the sound as it was musical and not fatiguing.
I have a question. If I was to use the RCA in on this unit, does that still utilize the DAC or purely AMP.
Using this as a DAC/Pre Amp is a no brainer, but I wasnt sure the other way around.
I was considering buying a second DAC depending on what phones I am using.
The single RCA input jack labeled COA, is a digital S/PDIF coaxial input, which would feed a digital audio signal to the DAC.
Hi Scott
The HD650 are what I'd call slightly on the dark side. The HD600 (while quite laid back and natural) are not what I'd call dark.
I tend toward a neutral to slightly 'warm' preference.- and I loved the NFB-12 (same/similar to the NFB-12) with the HD600. Didn't find it dark at all.
As I said I have not heard the 600s but had heard 650s and assumed they were very similar.
