Modding for better Bass - Dynamat or Vinyl Damping?
post-7573675
Thread Starter
Post #1 of 6
WaveRider69
I was going to get some Dynamat then I saw this other Vinyl stuff that claims to be better.  What do you guys think?
http://www.parts-express.com/pe/showdetl.cfm?PartNumber=268-030
post-7573941
Post #3 of 6
WaveRider69
It should give some better impact, accuracy, and detail.  Sort of like when using sound damping material in speakers.  Instead of the cheap plastic housing on most headphones.
I think I'm going to give the vinyl stuff a try.  I think while I'm at it I'll do some recabling too.  What gauge cable do you guys recommend?  What size is the factory default usually?
post-7573964
Post #4 of 6
Ishcabible
22awg is what I use for full-sized headphones.
And adding damping like the vinyl suppresses funky backwaves that mess with the sound.
post-7574207
Post #5 of 6
WaveRider69
Cool sounds good, so do you think 1/8" flex tubing would be enough or should I get 1/4"?
post-7574496
Post #6 of 6
Ishcabible
1/4 would be the safe choice.
