SDA
- Oct 5, 2004
Searches here and on Headwize revealed nothing relevant, so I decided to start a thread to ask for help with a problem I'm having with a MINT. If I just suck at using the search function, feel free to tell me so.
Now then, the problem. Everything sounds good (or as good as things get with my $2 test headphones) for a few seconds, then all of a sudden things get nasty, crunchy, and distorted. At first I thought that the NiMH battery I was using for tests was just dying and caused the opamp to clip, but when I left my multimeter's leads on the voltage test points the voltage stayed at around 9.5v (it was just topped off) through the Point of Ugliness. OK, so it dropped by a couple millivolts, but I don't think that would be an issue. Besides, when I tried it with an alkaline I had on hand it did the exact same thing.
Then I decided to test DC offset. I didn't know how to test much else, and I figured I was bound to happen on a useful measurement eventually. I did: DC offset on the left channel stayed at 0-1mV for a few seconds, then suddenly started to rise (quickly, this can't have been happening over more than half a second), then went all over the map (28mV to negative 10mV, moved around too quickly for my DMM to give me more than readings here and there) at the exact same time that things got ugly. The same thing happened with the right channel.
I've cleaned the board, checked my connections, checked voltages... what could be the problem here?
