Pars
Can Jam '10 Organizer
- Oct 28, 2003
Hi,
I am in the process of recasing a MINT I built about 4 months ago, and which has always worked fine. I wanted to convert it to wall power for use at work, and had picked up an Elpac WM113, +/- 12, +5V wallwart (was way cheap on Ebay).
I am putting it into a Hammond, and had te room, so I built a board with 4x1000uf Muse caps, and a pair of 1N4002 diodes on it. I removed the TLE on the amp board, the switch (jumpered it), and the crowbar diode. It is wired like:
I have a DPDT switch in the +/- 12V line before the diodes. I double checked everything, both ohming it out, and voltages to make certain that it was all wired up correctly (it is all connectorized so it is easy to check here and there).
The problem: the first time I powered it up, offset was as before, 0.000V per channel (limit of my one DMM). However, the second time I powered it up, the right channel went to +10.2 V, and has stayed there. Nothing appears to be getting hot, no magic smoke, etc. Left channel works fine (verified with phones jumpered in on one channel... I didn't have any around that I wanted to toast on the right channel).
So, it would appear that I smoked either the BUF634 or the right channel of the opamp (AD8620), or both? Any way to tell which before I order parts? Any glaring deficiencies in the additional caps circuitry, or the implementation in general?
Thanks,
Chris
Thanks,
Chris
