rayk
- May 20, 2009
Hello,
Finished my mini3 build last and....
For some reason the battery starts to heat up heaps when it is in use. Also the front LED doesn't light up.
It does produce sound (and sounded good in the brief period I used it), but with a battery running so hot and no glowing led I don't think it's a good idea to use it...
Checked the circuit, looks to be clean with no solder bridges.
