I'm at the end of my Mini3 build and purchased a Tenergy battery to use. With the battery contacts filed down to correct size the battery is still too tight to fit. The outer plastic (the Tenergy label) tore so I completely removed it. Underneath that was another clear plastic wrap around the plastic battery casing. The battery fits a little better but this clear layer is beginning to tear/impede proper insertion. Would it be safe to remove the clear wrap as well? The battery might just fit without this. I just don't want to remove it and risk the Mini3 or the battery.
Thanks
Thanks
