wgr73
- Mar 19, 2007
Hey guys, I think the mini3 supplied battery is a rechargeable NiMH...can I use a regular alkaline 9v battery (when the NiMH runs out or do I have to use the rechargeable)?
Originally Posted by aaron-xp /img/forum/go_quote.gif I do remember AMB saying something about using the relationship between using a regular alkaline battery and decreased performance due to the current draw. Don't quote me on it though. |
Originally Posted by darkfury18 /img/forum/go_quote.gif The board is attached to the front plate. If you remove the two screws in the front you can slide the whole board out. Alternatively, if you already opened the back, you can remove the volume knob and unscrew the nut attaching the pot to the front plate and you should be able to slide the board out the back. Good luck. |
