mgburch
- May 15, 2011
When you get rid of the resistor you shut down your High pass filter, so no filtering at all. I think i its there to avoid some undesirable behavior or artifacts (Transient oscillations) coming from the DAC, so leave it there =D.
But isn't there another resistor across the input of the preamp? I guess you can't count on that. Anyway, if there is a resistor at preamp, then corner freq is based on sum of both 47K plus preamp, right? (By sum I mean formula for parallel resistors, not arithmetic sum, of course).
Anyway, everyone says leave it, so I won't mess with it. I don't think it hurts the sound as its not directly in the path. Just wanted to be sure. With this simple I/V every part matters!
