amb
Member of the Trade: AMB Laboratories
- Apr 1, 2004
Nospam, no resistor in the Millett comes close to dissipating 1/8W, so RN55s will work just fine.
Originally Posted by Nospam Thanks! Good to know, but now I have to ask, just because I'm that way ![]() Why are 1/4W resistors called out in the parts list, if 1/8W are OK? |
Originally Posted by Nospam Why are 1/4W resistors called out in the parts list, if 1/8W are OK? |
Originally Posted by diskostu Do I need to connect the alps pot to the alps ground pad on the original revised millet board? |
Originally Posted by n_maher In my opinion it's safer to ground it as I've never had a problem by doing this, but I've certainly had issues when I did not. My 2¢, Nate |
Originally Posted by diskostu Did you used the top left screw on the back of the alps for the ground connection (like wrapping the wire around the screw)? Thanks -David |
