n_maher
Resistorous Conflagorous
- Nov 20, 2004
Mine is similar to AMB's but I used the 70052 15VA transformer and LM317 regulator. I'd have to recheck my notes to see what resistors I used but my guess is that it was 100 ohm and 2.0K.
HTH,
Nate
Originally Posted by amb Not Nate here, but my STEPS for the Millett has 120 ohms and 2K ohms for R3/R4 and the output adjusted to 27VDC. I am using the Amveco 70062 25VA transformer and the LM338T regulator which are a bit of overkill but I wanted to be able to use the same supply for other amps too. I am also using another identically-configured STEPS for use with my M³. |
HTH,
Nate
