hk29
I picked up a used MZ3. I'm a sucker for good looking gear. I knew I wanted to try something in the high-end to understand the diminishing return curve. It came with:
I'm coming from schiit MJ2 and using an abyss 1266. When it comes to tubes, I'm still a novice and the whole of tubes is so confusing with all the variants. I picked up a Sylvania JAN 6sn7gt as they're supposed to more detailed, and more air that I'm hoping will give some contrast to the tubes above.
As for the 12at7, I haven't researched much so still learning @jonathan c you recommended the rft. Is this the right one https://www.thetubestore.com/rft-ecc81-12at7? I'm not sure what I'm looking for yet and how to think about mixing between the two tubes.
So far no regrets in the move. It has enough power for the 1266. It's provide more of the tuby sound I was craving. It is more refined - smoother but more detailed and holographic. I normally listen in the 70-80db range. 80db is loud for me. I also listen to a lot of vocal centric pop and indie which doesn't normally have a wide dynamic range. I don't hear any compression or distortion when I'm in the 80db range.
that said the MJ2 was no slouch. I was very happy with it. And could easily live with it.
I'll post more impressions as my brain burns-in more.
- Psvane 12at7
- RCA Jan 6sn7gt grey - slightly warm, balanced top to bottom, detailed.
- Kenrad VT231 - full body bass, rich tone midrange, holographic
