Hello all,
First things first, the
stock Melodious MX-U8 sounds very good, but, not as good as my modified Gustard U12.
The modded U12 has more detail, tighter bass, bigger soundstage, and has less (=no) listening fatigue.
But, since stock MX-U8 came very close to my modded U12 I decided to select the best components to modify
my MX-U8 and take it to a much higher level than stock version.
My plans were:
-1 Replacing the 4x 2200uF-25V BC caps in power supply
-2 Replacing the cheap bridge rectifiers
-3 Replacing the two XO's for audio frequency
-4 Feeding the two XO's for audio with complete seperate power supply
-5 Replacing the crappy IEC320 power inlet
-6 Replacing the 2x9V 15VA Noratel transformer
-7 Adding a second transformer for powering second power supply
-8 Creating a copper shield between transformer compartment and pcb compartment
-9 Shielding enclosure and components with 3M AB5100s
-10 Replacing the RCA for SPDIF output
First I took MX-U8 apart and measured what kind of transformers I could put in this enclosure.
I found some R20 R-Core 28VA transformers which could fit in enclosure, but, to accomplish I had to move
the IEC320 power inlet to the outside of the box.
So I started to make a wooden block to mount the IEC320 on the outside of the enclosure.
I bought a RED copper, Rhodium plated IEC320 inlet of high quality and mounted it with
the wooden block on the backpanel. I mounted it with 2-component glue to the backpanel.
I ordered 2 R-20 size 28VA 2x7V R-Core transformers with copper shield and static shield (earthwire).
The base plate of those transformers were too big, so I had to cut of some metal before I could fit them
in enclosure.
I also had to remove some aluminium from the frontpanel (at the inside) to fit the transformers.
The copper strips (5mm thick), which I bought to create the copper shield, had to fit in enclosure,
and i had to drill some holes in it. This wasn't as easy as I thought it would be,,,,,
Then i did put all together and mounted it on the baseplate of the enclosure.
When putting all together I noticed I did miscalculate,,,,,, the wooden block wasn't thick enough,
so there wasn't enough room,,,, I decided to place some spacers between backpanel and screw holes.
(I will order a new backplate when I decide to make an HDMI-I2S output)
I started to assemble the Ultra Low Noise ( 0.8 uV ) power supply from DIYINHK.
The Panasonic FC caps were replaced with 4700uF-16V Nichicon FG's
Then I started to remove the BC caps from main pcb and replaced them with 4700uF-16V Nichicon FG's.
For the ones who ask themselves why I used 16V caps instead of the stock 25V caps:
The stock power supply power rail delivers a max of 9.5V before regulating (when using transformer with 7V output)
This also counts for the Ultra Low Noise power supply.
25V is way over-dimensioned, and when using 16V I could choose a higher capacity.
After replacing the caps I decided to try replacing the crappy bridge rectifiers with Cree C3D02060 ones,,,
I desoldered the bridges, and also desoldered the stock RCA.
It's a little tight, but it works and fit nicely.
Then I soldered the Gaofei Rhodium RCA and the powerconnector for the pcb and mounted it in enclosure
Then I started to fabricate the NDK NZ2520SD XO's. I received some adapterboards from
member hgpsemaj (thanks again Riemann) which made this task A LOT easier
I soldered some pins on the adapterboards, and soldered the wires from the Ultra Low Noise
power supply directly to the adapterboards. I mounted the decoupling caps (rifa 0.01uF) under
the adapterboard, as close as possible to vcc-gnd NDK2520SD
Finally I put some 3M AB5100s leftovers in enclosure and on the components.
I closed enclosure and started to burn-in the MX-U8
Last Sunday I started burn-in time, so today, this evening, it will have 120 hours burn-in time,
which probably isn't enough. For good listening impressions I will wait one extra day before final verdict.
But, to lift a corner of the veil:
Yesterday I couldn't resist and listened to the MX-U8. I had a very big smile on my face, and several times
gooseflesh (dispite of the high temperature which was about 38 degrees Celcius)
Soundstage is incredible, tons and tons of details, tonal balance is much better, it has much more overall body,
it seems it delivers huge dynamics i never experienced before, but, I could hear it wasn't completely burned-in.
At the low-end it wasn't bed in, it was tight, but for my taste too much pressure, so, not tight enough.
I know this is something which can settle-in when burn-in time has completed, so, tomorrow is another day for SQ impressions
Cheers
Alex
