Head Injury
- Sep 11, 2009
No, the speaker is not still turned on
Crosstalk is undesirable and electronic, and is not delayed. Crossfeed is the intentional mixing of delayed signals to eliminate channel separation. If these headphones are designed to work like this, it is indeed crossfeed.
My point is that the effect is 1. Too weak to be meaningful, and to build an entire theory of soundstage upon, and 2. Too dependent on playback volume and ambient volume to be associated directly to soundstage performance, or compared between headphones.
I have pointed out flaws in your reasoning and logic. The effect is too weak to be meaningful, from my perspective. It is far, far weaker than the effect the recording itself has, and seems to pale in comparison to the effect that driver placement has. And because there is not necessarily a correlation between headphone isolation and sound bleeding between channels (as I indicated with the Grados and LCD-2) there isn't necessarily a correlation between this proposed crossfeed effect and isolation, as I believe you originally implied.
And of course if it were significant, it is a severely unnatural effect and I doubt would improve imaging in any way. Speaker crossfeed is natural. Crossfeed plugins are designed to be as natural as possible. Headphone crossfeed in this example would have too low volume and too long delay to be able to accurately mimic real life.
At this point I expect proof that it is significant and "perceptible by a perfectly healthy individual"
