The default filter is not linear phase, that is my point. At least not with the DACs i own/tested.The linear phase default filter is transparent. Minimum phase filters cause phase distortion that might not be transparent to human ears. What people prefer is not the same thing as what is transparent. If you prefer phase distortion then you probably prefer minimum phase filter over linear phase filters.
It should be, i 100% agree with that, but for whatever reason i do not understand, with modern DAC from ESS and Cirrus (not sure about AKM), linear phase filter are no longer the default. At least not with the DAC i have used so far. They all default to minimum (non linear) phase out of the box...
The worst thing is, the manual doesn't even tell you that. Some DAC give you some nonsense descriptions likes "Makes everything sound bigger" or "Focuses on vocals" or stuff like that. I had to download the technical specification from the homepage of the DAC Maker to lookup which filter does what.
In the DAWN PRO, the linear phase filter is called "Phase compensated" which confused me because i haven't seen that wording for linear phase filter before. The CS43131 documentation also doesn't mention that, Moondrop made it up for whatever reason. I understand what they mean with it but it was confusing.
So sadly, in this day and age, we can no longer trust that an DAC, out of the box, sounds correct.
