bigshot
The truth...we don’t know if burn-in exists on certain products, speakers aside. I can’t prove to you that burn-in, say on orthodynamic headphones, exists, b/c I can‘t measure it. But no one has proven to me that it doesn’t exist.
How would one go about proving it *doesn't* exist? You can't go back in time and measure the before and after of the amp you are using now; and even if we could and we found out it didn't change with burn in, you'd just say maybe some other amp does... and we can't go out testing every amp in the world to find out.
You can't prove a negative. But you can prove burn in does exist. Go out and buy two copies of the same amp. Turn them on and do a controlled listening test to see if you can hear a difference. If they sound exactly the same, as they should, turn one off and let the other one play for a couple hundred hours, and then compare them again. Is it audible now?
People have done these sorts of tests and haven't found audible differences. People who have never done a controlled test in their life say "a veil has been lifted". Whose opinion do you want to go with until someone actually finds proof of audible burn in? I know whose opinion I will go with.
Some electrical components are known to change over time, from batteries to capacitors. I don't know that this should be called burn in
As long as we live in a world where the second law of thermodynamics exists, that is going to be the case. I call that "wearing out", and it is both clearly measurable and clearly audible. Also, it degrades, sound- it doesn't improve it. Not at all the same as burn in.
