I have the A1 and the D2. Both are connected to a Win10 PC (FLAC) and the D2 is also connected to a Mac Mini (ALAC) and Shanling PCD3000A CD player. For headphones I mainly use Alessandro MS2 and the A1 is ported to a pair of JBL ProPerformers speakers. I've had the A1, with upgraded tubes, for a year and it sounds good. A couple months ago I added the D2 for higher rez files, avoiding PC noise and adding in a second computer and CD player. The D2 is good although I wish it went to 192KHz but as I only have a couple recordings at that level, I went with it. I now use it more than ever as my go-to mini/computer system.
I have not done any modding other than upgrading the tubes and changing the power cables. Nothing fancy in the cable area, just heavier and longer. Stock ones are too short for my use. I wanted to spend a while listening to it stock and allowing it time to open up. Every pair of headphones I have connected have had no power issues. Even my MB Quart 55's which are a power vampire. My JBLs are over 25 years old but still sound great. A simple two speaker setup using 4-1/2" Full Frequency drivers [6-1/4"w x 6"h x 5-1/2"d], 10-60 watts per channel, sensitivity at 88dB and a frequency response of 100hz-18Khz. They handle bass surprisingly well. JBL did offer them as a set with a subwoofer but I never saw the need in a small listening environment. Going forward a year, I might upgrade the Mavericks a bit more but before I do, I intend on upgrading cables (from stock) and focusing on replacing any poor rips I have with better and higher quality. That will give the units, and my ears, time to settle in, and go from there.
As I said, all headphones (on-ear, over-ear, in-ear) I have tried (Grado, Audio Technica, Sennheiser, Quart, Bose, AKG, Logitech, Koss, Sony, House of Marley, and Philips, have had no power shortcomings. All were driven well. Hope this helps you (or someone else) get an idea of Maverick power and sound. At their price point, they are well worth it. I spend more time listening to this mini computer setup than my Adcom, Sony, Aiwa, Arcam, NAD, Cambridge or Krell. I've started a journey to pair down my accrued hardware in favor of quality and simplicity (to my ears) over quantity. I gave up vinyl and tape and stick with CD and digital (growing library). I find I am listening more now than ten years ago and I attribute that to decent new equipment, digital music and the simplicity both bring to today's busy lifestyle ... web surf or read and listen!
Cheers!
