I just snagged an N5909 lightly used for $375, but it's missing a USB C audio cable. Any ideas on where I can pick up a replacement? Thanks.
Mark Levinson № 5909 headphone
- Thread starter JML
AKGunkie
Member of the Trade: Harman (Automotive Audio)
- Sep 13, 2014
The usb C to usb A? I can check if any of my other cables work for it
It's a proprietary cable. That's the challenge. Thank you for any help.The usb C to usb A? I can check if any of my other cables work for it
XTF1
- Nov 9, 2014
It should be available at Mark Levinson, or not? Are you ready to make (solder) your own?It's a proprietary cable. That's the challenge. Thank you for any help.
you can connect ML and order from them directlyI just snagged an N5909 lightly used for $375, but it's missing a USB C audio cable. Any ideas on where I can pick up a replacement? Thanks.
That would be great! I hope that's possible.
Not ready to do that at all.It should be available at Mark Levinson, or not? Are you ready to make (solder) your own?
that's how I got a bank up wire back in the dayThat would be great! I hope that's possible.
That's encouraging. Thanks.that's how I got a bank up wire back in the day
I bought the 5909 a couple of weeks ago on sale for 550 and I am very satisfied so far. But I wanted to try how it sounds via USB, but I could not get it to work. I plugged it directly into my iPhone via USB-C to Lightning Cable, but the phone did not recognize the 5909 as an audio device. On my pc I plugged them into an USB Port, but all I could hear was loud static, so I immediately unplugged them afraid it would damage the headphones. So long story short, how can I use them wired? I wanted to see how big the difference to the lossy bluetooth is. Thanks in advance!
stiggy771
- Apr 19, 2012
In PC did you check the sound output option. You may have to select it instead of the default option. Works fine using the USB c cable for me on my PC.I bought the 5909 a couple of weeks ago on sale for 550 and I am very satisfied so far. But I wanted to try how it sounds via USB, but I could not get it to work. I plugged it directly into my iPhone via USB-C to Lightning Cable, but the phone did not recognize the 5909 as an audio device. On my pc I plugged them into an USB Port, but all I could hear was loud static, so I immediately unplugged them afraid it would damage the headphones. So long story short, how can I use them wired? I wanted to see how big the difference to the lossy bluetooth is. Thanks in advance!
Try the 3.5mm wire. I don't use the USB C to USB C outside of charging the headphones
XTF1
- Nov 9, 2014
What USB cable were you using? The ML5909 cable is (semi) proprietary…I bought the 5909 a couple of weeks ago on sale for 550 and I am very satisfied so far. But I wanted to try how it sounds via USB, but I could not get it to work. I plugged it directly into my iPhone via USB-C to Lightning Cable, but the phone did not recognize the 5909 as an audio device. On my pc I plugged them into an USB Port, but all I could hear was loud static, so I immediately unplugged them afraid it would damage the headphones. So long story short, how can I use them wired? I wanted to see how big the difference to the lossy bluetooth is. Thanks in advance!
Ah did not know that, I was using an off-brand USB Cable, thanks!
streetbeat
@HennesVI
Just tried them using some random Baseus USB-A-to-C cable on Dell XPS laptop (Linux) - works with no issues.
Not an iPhone user, but is there a chance your iPhone rejects connection because 5909s are trying to charge when plugged in?
