Asakurai
mt4 is still a bit similar with tea sound signature, but the bass is slow, too slow for my preferences
I actually did receive the new packaging. Ordered two weeks ago and received it last Wednesday. Almost thought I received a clone because of the new packaging, but it's from Linsoul and seems to be an upgrade to the previous packaging.Hello
I just found out on the Linsoul website that the Mangird Tea seems to have a change in their package. It now has a leather case, a different box presentation and different tips. It also includes one 6.35 mm adapter and one of those airplane socket adapters.
Does anyone know of someone who has already received this package?
Yes, my Tea was delivered yesterday with these peripherals. I ordered the 2.5mm cable, but the two adaptors don't fit, they're for 3.5mm. I don't like this style of case (like a larger version of what came with Tin P1), the magnet which is supposed to hold it closed is too weak to stop these cases accidently opening if I'm carrying it in my knapsackHello
the point is the sound guys....................and at this point the Teas are the hottest thing out there at this price range for sure................trully exceptional midrange,in comparison with other multi-hybrids back to back auditioning, they sound day and night difference.................Yes, my Tea was delivered yesterday with these peripherals. I ordered the 2.5mm cable, but the two adaptors don't fit, they're for 3.5mm. I don't like this style of case (like a larger version of what came with Tin P1), the magnet which is supposed to hold it closed is too weak to stop these cases accidently opening if I'm carrying it in my knapsack
Tea definitely livelier and better technical for sure, tea bass punch much harderHas anyone compared the Tea with the SeeAudio Yume? It seems they have some similarities, comparing reviews of the Tea to my experience with the Yume.
Tea also warmer and thicker than what yume offer, yume focused on midrange while tea offer more balanced presentation
Yume stage is a bit wider while tea offer more depth.
I like both female and male vocal on tea, but only female vocal for yume
Well obviously in term of tech, i don't think Yume is on Tea level, while for tonal is matter of preferences
Thanks for your comparison. Drop has the Tea on discount right now so my interest was piqued. I think the Tea’s sonics will be covered by my Yume (female vocals and violin/woodwinds)
and my Globe as my main. OTOH, that is one nice deal on the Tea on Drop...
With you having both the Yume and the Globe, I do think the Tea would probably be a little redundant, or a side-grade.
agreed with IEMusic, Tea will be redundant against Globe imoThanks for your insight. Wallet! Back in the pocket!
Globe and tea , which one sings more physical and emotional/specious ,,,,,agreed with IEMusic, Tea will be redundant against Globe imo
Globe is the more musical and less technical version of tea
i own Globe and Yume, and also bought 2 Mangird Tea for my friend before
why i didn't buy Tea? i own too many IEM and i need to cut down some so i only pick the unique one (can be bad or good).... and i prefer musical one than technical one (although i do accept good technical with good musical IEM)
Easily Globe, tea midrange is great, it just globe is specialGlobe and tea , which one sings more physical and emotional/specious ,,,,,
Which has better imaging? I find the imaging of the Tea to be one of its strongest qualities. It has truly holographic imaging for me, only bested by the MEST, of all IEMs I’ve heard so far.Easily Globe, tea midrange is great, it just globe is special
Choose Globe if you like female vocal and string instruments
Choose tea if you want more textured bass and better detail
