quane
- Feb 28, 2009
I know, I know.. There's been 100 of threads like this, but each of us is unique and needs different things
If I will start building a CMOY, it will only happen after about a month or so (at least) because I need a pair of suitable headphones first. I've looked at some CMOY threads but usually people only show pics and not say anything. So, I got couple questions.
I need all parts from UK as I live here
I plan on making a CMOY that will have 1 volume knob, 1 on/off switch, 1 LED for the front, a mini or 1/8 (6.5mm jack) and I'm un-certain for the rest. I'm a total newbie, so bear with me. It's gonna be sitting at my house and I need something that would be value/performance as I don't have that much of a budget. I can't decide between internal PSU (probably those big batteries) or an external one (it would probably cost more), which is a better choice? This CMOY will be used for PC (not onboard audio).
1. Is Metal housing cheap? Where could I get it (except ebay and only UK), or could I make it myself (don't really want tin from mints)
2. How much would a pretty ok cmoy cost (estimate, all parts ordered from UK.)
3. What components do I need?
4. What is the drill called that you would use for circuits? ( I used it in Technology at school, 2 years ago but can't recall the name.)
5. What other tools are needed for an "OK" build?
If I have anymore questions, I'll post them
Thanks
Thanks
