xnor
- May 28, 2009
The article you linked clearly states most MRI scanners use a constant magnetic field which behaves identically to a permanent magnet. These are just permanent electromagnets running huge DC currents through superconductors to produce intense magnetic fields.
Yes, as I said, a constant magnetic field is part of MRI scanners.
Second paragraph:
A radio frequency electromagnetic field is then briefly turned on, causing the protons to alter their magnetization alignment relative to the field. When this field is turned off, the protons return to the original magnetization alignment, and these changes in magnetization alignment cause a changing magnetic flux, which yields a changing voltage in receiver coils to give the signal.
The source study for that article has since been removed...I wonder why.
Because they have completely changed their site and their archives don't go back to 2004 anymore.
http://www.ncbi.nlm.nih.gov/pmc/articles/PMC1241963/
