Euhm. how about Monitor Audio's, Genelec's, Jamo, Spendor, ATC etc. They have some great speaker, but I would never call them 'greatest, best possible sounding speakers under 2000$'.
Ok, well which of these speakers are the best possible sounding speakers under $2000? I just want to make sure that I get the best possible sounding speakers for my money. There are much better things to do with your money than audio..
you dont really sound like you're in the right place....haha
Like uncle erik said, its a very personal thing that we cant give you a simple answer to.
First you should figure out what kind of sound you like, and what music you'll be listening to.
What amp you're gonna want to use, or at least what your options are...and what the room these will go in looks like.
Then look into as many speakers in that price range as you can to see which ones suit all these things above best.
You should be doing at least that if you're planning on spending two grand on speakers, plus however much more on amps/sources.
Your attitude leads me to believe you're jumping into this while not wanting to do much research or work yourself. I'd reconsider if thats the case......
