probably, anyway charts only tells one side of the story - but I think in this case I compared both and K6 is probably tuned bit more better.. more musical and not as dry and neo bgthat measurement is near identical to my k5 measurements. shozy neo bg is 5BA, so both are 5BA chinese oem rebranded, probably.
i don't know about the silver/white, but this black silver plated copper cable hasn't got great conductivity. dc resistance (L+,R+,L-,R-, in mΩ): 546 545 452 478. weight: 24.9g.
not impressive at all
Magaosi K5
- Thread starter all999
expatriot
I own the K6 and love it. I was a little surprised at first do to the smoothness, but still reveals a lot of details. Just received my K5Pro Bass and they tuned the bass perfectly to my ears. For me the K5Pro is my favorite iem under $200. I never owned the original K5 or V2, but I am willing to bet that those who liked the K5, but wanted a little more bass, will fall in love with the K5Pro.
Ted Presley
Would you like to tell me the main differences between K6 and K5Pro, I currently keep K6 (used to own K5).I own the K6 and love it. I was a little surprised at first do to the smoothness, but still reveals a lot of details. Just received my K5Pro Bass and they tuned the bass perfectly to my ears. For me the K5Pro is my favorite iem under $200. I never owned the original K5 or V2, but I am willing to bet that those who liked the K5, but wanted a little more bass, will fall in love with the K5Pro.
expatriot
Ted Presley:The main difference is that the Pro has more lower mid bass and sub bass, but the mid bass does not bleed into the mids at all. A little more musical. The pros shell is a little smaller and lighter, but only available in purple color.
expatriot
Ted Presley: Forgot to mention that although of great quality, the K6 cable was to stiff to my liking, where as the Pro's cable is very supple with a L plug termination. I prefer a straight termination, but it's not a deal breaker.
expatriot
liquidrats: I don't know why either. I own the TFZ Secret Garden 3 and it's underrated also.
I hated the stock cable, I wore for like 2 weeks and it broke. Swamping cables doesn't make alot of difference unless you're getting higher end (> then IEM).Ted Presley: Forgot to mention that although of great quality, the K6 cable was to stiff to my liking, where as the Pro's cable is very supple with a L plug termination. I prefer a straight termination, but it's not a deal breaker.
That's ok Music is for our enjoymentliquidrats: I don't know why either. I own the TFZ Secret Garden 3 and it's underrated also.
Orl14
Whats the next sub $1000 upgrade from the K5? Looking for an iem with good upper mids and treble.
Thinking about the KXXS, TFZ No. 3, ATH-LS200iS, or maybe go straight for the FH7.
Redcarmoose
I would at least try the Fearless S6Rui.....6BA for $389.
expatriot
NF Audio NF3U, I bought it for the upper mids and lower treble. The bass is very good for a all ba iem. Head-Fi has a few reviews which are all good, and hbb gives it a rec also.
expatriot
I'm in the Philippines also, what province are you located?
Orl14
Cavite and Pampanga, though I can easily go to manila if neededI'm in the Philippines also, what province are you located?
expatriot
Too far, i'm in Cebu. You can pm me and I'll tell you all about the NF3U.
- Jan 10, 2016
The best from Magaosi to date for me - **** (Have not tried the DQ4 though). I like how it has a more forward upper midrange than the K6.
Agreed. The NF3U has a detailed sound with articulate top end. The bass may not be full-bodied enough for some but it is very quick. Enjoy your NF3U!NF Audio NF3U, I bought it for the upper mids and lower treble. The bass is very good for a all ba iem. Head-Fi has a few reviews which are all good, and hbb gives it a rec also.
