Hybrys
- Dec 20, 2009
That's correct, ROBSCIX is mistaken. The RCAs are supposed to be volume controlled.
Edit: According to Nuforce, you're supposed to set the RCA volume level at 'whatever volume optimizes your amp'. So try different levels, and see if it starts to sound better. As long as there is no distortion, there's no other volume you can't try.
What amp are you using in conjunction with it, by the by?
If that were the case, wouldn't the volume knob stop working when output to the amp? The volume knob adjusts the volume whether outputting via the headphone jack or RCA for me.
