mrksgrn
- Aug 16, 2011
I've received my new M-Matrix today from Tam and everything seems fine and dandy (fixed the humming by tightening bottom screw), with the exception of heat.
It is running quite hot out of the box. No class A bias.
My setup is HRT MSII > M-stage Matrix > ATH PRO700 / HD650
Is this normal for the unit to produce so much heat in normal operation? Has there been reports of failures due to heat?
Should I be turning the unit off if I'm not using it or could I leave it on 24/7 as I do with my computer?
Thanks in advance!
Thanks in advance!
