m-audio help
- Thread starter oofie810
morphie
- Nov 13, 2004
- Messages
- 1,175
- Reaction score
- 10
Hi,
1) Yes, you can. You can plugin any CD/DVD players to the audiophile USB via RCA inputs, and listen to music via the headphone out.
2) Through the RCA output. Never connect anything thats not headphones on the headphone out.
3) Yes. The headphone out is made so you can plug in your headphones right away to listen to music. The Grados being easy to drive, they should sound great straight out the headphone out. However, being a decent amp later on would be a nice idea.
Hope that helps
Hope that helps
oofie810
- May 25, 2005
- Messages
- 145
- Reaction score
- 10
Thanks for the very informative and fast response, but please, pardon me for all these questions.
1) By "sound great", would that mean better than just using the headphone out of my laptop?
2)Ive also considered just using the m-audio transit and a pocket amp, which would you guys think will sound better, transit+pocket ampv2 or the USB audiophile alone? I just checked my finances and as much as I hate it, I think I can only spend up to around $160. With the audiophile being 155, I guess if i buy that, I have to use it alone.
Originally Posted by morphie Hi, The Grados being easy to drive, they should sound great straight out the headphone out. However, being a decent amp later on would be a nice idea. Hope that helps ![]() |
morphie
- Nov 13, 2004
- Messages
- 1,175
- Reaction score
- 10
I'm not convinced the pocket amp will make things any better. Its good for portable use. Personally if I were you I'd use the line out of the computer and buy a nice amp instead of a soundcard. If you dont plan on building a hi-end system thats probably what will change the sound most.
oofie810
- May 25, 2005
- Messages
- 145
- Reaction score
- 10
But my ibook doesnt have a line-out
but will it be ok if just connect the amp using the headphone out of my laptop? Im thinking of buying an external soundcard if it can drive my headphones better than the headphone out of my dvd player or my laptop, and then buying an amp afterwards.
Originally Posted by morphie I'm not convinced the pocket amp will make things any better. Its good for portable use. Personally if I were you I'd use the line out of the computer and buy a nice amp instead of a soundcard. If you dont plan on building a hi-end system thats probably what will change the sound most. |
morphie
- Nov 13, 2004
- Messages
- 1,175
- Reaction score
- 10
line-out = headphone out. In that case I think you should buy the amp first, and an m-audio transit afterwards if you wish.
oofie810
- May 25, 2005
- Messages
- 145
- Reaction score
- 10
ok i guess ill just go the transit+portable amp way first and upgrade as my needs and finances grow, thanks a lot for replying!
Originally Posted by morphie line-out = headphone out. In that case I think you should buy the amp first, and an m-audio transit afterwards if you wish. |
